Solar Panel help needed
- Minniemouse
- B190 Year: 1996
Minniemouse.....be sure to check the other 2 posts in the Electrical forum for additional info related to the solar panels also...
Re-posted...from Steve Holm...(webscrambler)
Kyocera 120 watt solar panel
This unit fits just between the air conditioner and the bed room down angle (1995 190)..and just inches to spare on either side of roof rack.
Grey box on top has the solar wires. 1 RED wire & 1 WHITE wire...
The wires are above the interior light.
Those wires run to the converter.(mine were capped with wire nuts at each end).
Forget trying to use these wires to pull larger wire...they are tied to the other coach wiring behind the paneling.
The factory installed solar wires are located under that small cover on top just ahead of your air conditioning unit..
Re-post....from Steve Holm
Solor Panel used...Kyocera 120 watt solar panel
After doing extensive research on solar panels I decided to use this panel because it was the largest that would fit the top, produced the most and was the most efficient for the money. Most people using solar panels suggested that they wished they had gone to a larger panel than they had...so, I doubled the capacity I thought I'd need. A little more money buys a lot more panel.
Also, ask if they have blems..a panel should last over 25 years and a scratch on the aluminum frame will only be seen by God and the birds...I saved $100 this way.
Don't forget to use a controller between your solar panel and converter box ( I used a sunsaver 10 amp). I also purchased a AGM (absorbed glass mat) battery...completely sealed, use in any position, no fumes....and located it behind the sofa.
_________________
_________________
