Airstream B190 - 1994 Ford E-350 460 Gasoline Engine. 166,000 miles with 2 big Solar Panels on the roof.
Now $7,500 or make me a good offer!
Easy to Drive and Easy to park. You can camp anywhere in this van ! and Trust me I have ! It's got a big engine for a little van so you can pull anything. I have only ever pulled my harbor freight trailor loaded with about 800lbs.
Gets about 13 mpg on the highway at 60mph.
Lots of Photos are here at this link:
http://www.emuvideo.com/images/rv/
It is a fully Self Contained Unit. You can shower/use the bathroom/cook/sleep and never leave the van (but that's no fun). Too much to mention. Comes with all Original Manuals from the Factory.
A new Transmission was installed around the 90k mile mark.
Here is what I have done to the Engine in the last 10,000 miles:
- Replaced Front Brake Pads
- New Fuel Filter along with a Fuel System cleaning from Jiffy Lube
- Replaced Drivers Side Window Regulator
- Major AutoShop Work done - New ECM Computer, Spark Plugs/Wires and Distributor Cap.
- Major AutoShop Work done - New Timing Chain and Cover along with a new Water Pump
- Replaced the Coach Battery with an Interstate Deep Cycle
About 2 years ago I did the following to the Onan Generator:
- New Starter Motor, Fuel Lines and Filter
It's an older van, somethings need work. For exmaple The Fridge runs on propane but sometimes it won't stay on. I have an inverter and run it on 120Volts and it gets cold (freezer down to -2F).
Some of the Curtains need some TLC.
I have 2 big Solar Panels on top along with an Wirthco 150amp Batter Isolator to keep the coach battery constantly charged.
To be honest you really never need the generator, often I run it on a regular basis just to keep the generator in good condition and not let it sit too long.
I've had my 3 boys in the top bed, and I sleep on the bottom fold out couch bed pretty comfortable.
I've had many years of great memories but with a growing family, this is getting too small for my needs. Love it though as you can park/camp anywhere with this thing.
Regards,
Damien
505
818
9645
For Sale 1994 B190 in Albuquerque, NM $7,500
Re: For Sale 1994 B190 in Albuquerque, New Mexico
I'm definitely in the market for a B190 and I like the fact that you are reasonably close to me as I'm in central Texas. Could you send more information about the condition of the body and the drivetrain to jimf@nctv.com? Has it been in any wrecks, is there any rust or dents? Has it been regularly maintained and has it had any major drivetrain work done to it and if so what? I did note the items that were replace in the last 10k miles. Thanks,
Jim Fowler
Marble Falls, TX
512-589-3964
Jim Fowler
Marble Falls, TX
512-589-3964
Re: For Sale 1994 B190 in Albuquerque, NM $7,500
Sale is Pending. Thanks
Safe to assume the sale went through?
countryfish
- New User
- B190 Year: 1989
Did you sell it, I'm in ABQ and would be interested.
Sent from my AOSP on Deb using Tapatalk
