I have recently acquired a 1994 B190 and I'm currently getting everything in order, I noticed non of the door lights had any bulbs, so I of course replaced them. While doing so I saw heat damage to the mounting systems. I thought maybe the wrong size bulb, but what I have found is unlike many mini vans these dome, and door lights can't be shut off at the light switch for the headlights. That causes these small door lights to stay on for extended periods, thus the heat damage.
My B190 is being setup as a kiteboarding windsurfing lake vehicle and I was wondering is there something I'm missing or how have any of you tackled this problem. I want to be able to disable all the light bulbs up in the cab, when my doors are open for extended periods and that may be most of the day.
Thanks,
Eric
Vehicle cab light bulb switch.
Re: Vehicle cab light bulb switch.
I took the bulbs out of the door lights on my 93.
Same here, I used to own a 95 E250 Sportsmobile and it had what they call "puddle" lights. I also noticed the bulbs were missing, duh... when I replaced them they would stay on every time the doors were open. Bye Bye bulbs.
My 99 B190 doesn't have these lights, and I don't miss them one bit. Have a good day.
I'm not familiar with the lights you're describing, but you could also replace them with LEDs. They draw so little power that your battery would be fine even if you left them on for weeks on end.
- sparky
- B190 Year: 1995
I disabled the lite switches for the side door and rear door. Figured i may leave those doors open and never the cab doors. Just unscrewed the nut from the switch and pushed the switch thru the hole.
