I need to replace the water pump on my '93
General Mopars
Post by General Mopars »
And I mean the water pump for the freshwater system, not the coolant pump for the engine.
I see several different kinds of pumps listed on ebay. Does anyone know the specs of what I need to order to replace it?
Re: I need to replace the water pump on my '93
Post by Keystone »
I bought this one for my '94--it's a Jabsco in-line pump model 36400-0000: http://www.westmarine.com/jabsco--pumpg ... 32_003_024
It's not the same model as was original to the van, but it's worked fine these past 4 years since I installed it. Good luck!
Post by Keystone »
OK, as I look at the literature on this thing, it might be only the strainer and not the actual pump. It sits on the floor in the cabinet under the sink, and the old one had frozen and cracked and was leaking. Sorry for the confusion...
FoCoKCCO
WBCCI: 8008
Post by FoCoKCCO »
The only thing that you really need to do is match the GPM and PSI of the old pump. I recently replaced the water pump in my '93 but I went with a slightly higher GPM to help the on demand hot water heater that I also upgraded. Good news is they are all reasonably priced from $50-$60.
1993 B-190
WBCCI: 8008
Fort Collins, CO
General Mopars
I don't know the PSI and GPM of the old pump. Also, ebay had a few styles listed as "on-demand" which is what I'd assume they are, but I'm sot certain.
FoCoKCCO
WBCCI: 8008
Post by FoCoKCCO »
The GPM and PSI should be listed on the metal plate on the pump.
1993 B-190
WBCCI: 8008
Fort Collins, CO
Post by Keystone »
Sorry, let me try again to answer the question that you asked instead of the one I thought I heard :D . The Shurflo pump in my '94 is the model 2088-403-144. It's been discontinued. I wrote to Shurflo, and just got this reply:
Thanks for your inquiry. Model 2088-403-144 has been replaced by model 4008-101-E65 and is available from local RV Dealers.
Sincerely,
Kevin McLean
Fluid Motion Technologies (SHURflo/Sherwood/Pentair) Customer Service
3545 Harbor Gateway South #103
Costa Mesa CA 92626-1457
So there you go! Let us know how the replacement goes.
Water pumps are water pumps - you can put in almost any model and it will fit. No need to stress over getting that exact model. For example, they have ones that are variable speed now, which sounds interesting (haven't tried it myself).
General Mopars
Thanks, I ordered a 2088-554-144, and I plan to install it over the weekend.
