Want to add an awning to my 1998 B190
I have seen numerous B190's with awnings and would love to add one to mine. When I contacted Airstream I was advised the awning for this year would have been a CareFree awning. However, they were unable to advise me if there is a support rail on my unit to support it. They also said they didn't have any of the schematics for how this section was built. My manual also doesn't address this issue. It is 16 years old and I am a bit concerned about adding it to this age fiberglass. Has anyone added an awning to this age vehicle and if so were there any fiberglass or support rail issues? Thanks!
jb1rd73
Re: Want to add an awning to my 1998 B190
I would check Fiamma's website and contact them the directly. http://www.fiammausa.com/
Thank you for the link. I'll check it out.
Sadly Fiamma advised there are no brackets available any longer from Airstream due to the angle of the topper so they can't help with an awning. Has anyone used a bag type awning or is there some type of salvage place I might could find one from a wrecked one?
jb1rd73
Try the ARB or Foxwing
The support rail would be obvious - it runs most of the length of the van and is on the fiberglass portion. Take a picture of the side and we can tell you. I would've thought Airstream installed them even if there was no awning installed, but perhaps not.
All of the awnings I'm familiar with require that rail - even the fabric awnings that rely on separate poles that are staked down slide into that awning rail.
Took a photo, but unable to get it to the extremely small size required to attach:(
Will have my son try later. Thanks!
You can upload it to the Gallery.top9303 wrote:Took a photo, but unable to get it to the extremely small size required to attach:(
Thanks for the info. The photo is the last one in the gallery.
hi,
i just bought a 1998 B190 and mine too doesn't have an awning and i'd really like one. Did you ever find something that would work?
thanks
Babsy
thanks
Babsy
First, I'm sorry, top9303 - I missed that you uploaded a picture. You don't have the rail, so I'm pretty sure you'd have to have one installed before you could put on an awning. I'd suggest talking to an RV dealer. I don't think it has to be an Airstream-specific dealer.
For reference, here's the picture:
Looking again at the picture, I'm not sure where the rail would go - it would seem the windows or vent would be blocked. For reference, here's my '91 with the awning:
This makes me wonder if ANY of the later models had an awning...I was sure we've seen some with them, but it's not clear to me how they would mount.
It's the same question as above - do you have the rail? See the pictures above.babsy wrote:hi,
thanks
Babsy
Thanks for your input. I did try an RV dealer. The problem seems to be they moved the kitchen from the driver's side to the passenger side putting the vent in the way. Bummer:( I always loved an awning!
- Tucsonan
The awning brackets on my '94 look like they could be easily fabricated, ...if you could find a shorter awning that ended before the range vent.
VT964x4
I have a '96 with the kitchen on the passenger side. It does have an awning. In the gallery under 'Northstar' you can see a photo of where it is attached. It is up pretty high, works well. Makes a really big difference.
- Tucsonan
My awning lost its endcap too, any luck in finding a replacement?VT964x4 wrote:I have a '96 with the kitchen on the passenger side. It does have an awning. In the gallery under 'Northstar' you can see a photo of where it is attached. It is up pretty high, works well. Makes a really big difference.
