The screen on the window above the sofa needs repair. Not sure how to remove it. Googled it in and either have to remove the plastic tracks it slides in from the metal channels, or slide screen to the middle of the window and press up on upper frame so lower frame can come out. Anyone done the removal?
We have spent about 50 days in the 190 so far this year. I think the Yorkie busted the screen, but not sure. Gotta blame something.
Answered my own question. The screen will not lift out unless you remove one of the plastic L shaped strips in the metal channel. I removed the bottom one(easier to see and work on) and the top of the screen frame then can be pulled inward and removed. Save the rubber bead that holds the screen to the frame. Apparently not a common size.
Phil
