I take it this is the stock converter, the single phase, that I want to replace w/ a 3 phase unit. Which unit are people leaning towards today and how easy for a some what mechanically inclined numb nuts to do.
I looked at Skaters old post on replacing his converter and per the pics, mine is the same model. I may have to give those people a call and see what converter is recommended these days.
I’d stick close to the same amp rating when replacing. You might be tempted to go higher, because you sure can, but the amp rating is there for a reason.
usachris wrote:I’d stick close to the same amp rating when replacing. You might be tempted to go higher, because you sure can, but the amp rating is there for a reason.
A larger one isn’t a problem. It just means you’d theoretically be able to run more 12 volt appliances simultaneously and still recharge your battery. There’s more than enough AC power available.
Example 30 amps at 12 volts is 360 Watts, which is 3 amps at 120 volts. The 60 amp converter would draw at most 6 amps - and then only when you are actually using 60 amps of DC power in the coach, which probably isn’t even physically possible.
Isn’t there a danger in running more power through wire harnesses that are rated for far less? Not sure Airstream installed wire harnesses that could power more appliances simultaneously.
usachris wrote:Isn’t there a danger in running more power through wire harnesses that are rated for far less? Not sure Airstream installed wire harnesses that could power more appliances simultaneously.
Yes, there could be. To be absolutely safe, you would want to check the gauge of the wire running from the converter to the panel. I would have to look at mine to see what it was, but it was pretty beefy. For that short of a run, even 6 gauge might be sufficient. The run to the battery is also pretty heavy cable. It’s at least the size of the battery cable I replaced.
I also went with the 60 also because I was concerned about the size of the 45 - it looked to tall to fit. Double check the measurements.
I also replaced the fuse panel, and the new one has master fuses of a certain size (I think 20 amps, actually), so there’s another layer of protection.
Hi Chris, Thanks for welcoming me to the site. I have a question about replacing my converter. I have the original B-W Manufacturing Model 6332 and it seems to be working fine but I just bought a new AGM house battery and I don't want to ruin it by overcharging it. So I'm looking at replacing the converter. I noticed you listed a number of converters and was wondering which one you went with. Should I stick with the 35 amp or move up to the 55 amp model. I might want to add solar in the future too. I'm fine with spending a little extra for the 55 amp especially if it gives me more options in the future, I just don't want to over load anything. My rig is a 96 Ford with the 97 Model Airstream. Also is it worth adding a switch to turn off the system and if so where would I put that switch? Mine has no disconnect switch that I can find. Thanks, Julie
I just sent you a PM but I’ll post it here as well:
I stuck with the original rating when replacing the converter - my thinking was that all the wiring was rated for that size controller. Skater went with a larger one - the thinking was a fuse would blow before the wiring caught fire.
I also installed 2 - 6v deep cycle marine AGM batteries for 440 total amp hours. Lifeline batteries are very good for RV application purposes - it’s more than I need but nice to have since I am running a compressor refrigerator.
My Factory installed battery disconnect is located in the long-skinny storage bay behind the drivers door, located on the outside of the van. Open the bay door and mine is located on the back wall of the storage bay.
Great chatting with you! Please don’t hesitate to reach out with any further questions. My wife and I have completed dozens of projects on our b190. You can check out a few of them in my photo gallery.
usachris wrote:I just sent you a PM but I’ll post it here as well:
