Seat belts for dinette and restraints for pets.
Traveling with friends?
GJCamper
WBCCI: 5019
Post by GJCamper »
My B190 is one of the rare ones with a dinette instead of a sofa. From reading posts here it appears that some of the sofa units have passenger seat belts. Does anyone know anything about seat belts in the dinette?
I plan to travel with 3 adults and 3 dogs. 2 small dogs and one large dog. Can anyone suggest how I make my dinette B190 safe for travel for everyone?
Judith
WBCCI 5019
ZachS
Re: Seat belts for dinette and restraints for pets.
Post by ZachS »
Hi Judith
We have a 92 with the couch. Our couch had the "jackknife" hardware removed, and the couch base modified, so I'm not sure if it is typical of others.
We have a trap door in the base that you can lift to access the void under the couch. The seatbelts are attached to the chassis in that void. I will pop out to the unit this morn and take some pictures.
Reorienting the belt attachment is something we are considering as we design a dinette to replace the couch. I'd love to see some pictures of your dinette setup. Do you think it's a factory option?
Thanks
Zach
ZachS
Post by ZachS »
Pics of our "couch"ImageImageImage
GJCamper
WBCCI: 5019
Post by GJCamper »
I will have to get inside the dinette and look for any sign of connections to the chassis.
How do I attach a photo to a post?
Judith
WBCCI 5019
GJCamper
WBCCI: 5019
Post by GJCamper »
Yes my B190 is one of the ones that came from the factory with a dinette, not a sofa. There is no sign of there ever being seat belts in the dinette. I'm going to have to figure something out.
WBCCI 5019
usachris
Post by usachris »
We don’t have the dinette but you might be interested in our pet restraint solution.
We installed anchor points through the floor of the van, under the couch.
There are four in total. We use them to attach to a restraint cable.
Here are the two restraint cables attached at both ends to the anchor points. These cables are wrapped through the kennels at pre-existing points for a secure fit.
Sorry the kennels are not in these photos but hopefully you can get the idea.
Christopher Salazar
1999 B190 #301352
GJCamper
WBCCI: 5019
Post by GJCamper »
Chris,
That looks like a great set up for the dog kennels! I think I will put the dogs in harnesses and attach a restraint cable on the floor under the dinette for the 2 little dogs to sit up there on one side. Then attach a cable to where the driver seat belt is attached for the big dog so he can sit on the floor towards the front. I will ask the RV place to install the dinette restraint cables and seat belt as I am not sure how to do it correctly. Having more than 2 humans on board means I will need to put in a regular seat belt as well. The sofa seems better suited to strapped in passengers than my dinette does.
Judith
WBCCI 5019
