VIN Decoder
VIN Decoder
I've now integrated the VIN decoder into the site! You can find a link for it on the navbar above, next to the link for the FAQ. Or click here! Please let me know if you have any problems - it was pretty well tested before, but I may have goofed somewhere during the integration.
Re: VIN Decoder
Thanks Skater - that's really slick! Worked great - the only think that looks funky is the Series mentions 'chevy'... maybe thats in the airstream DB.
[image][/image]
[image][/image]
- VIN.JPG (44.19 KiB) Viewed 13978 times
Re: VIN Decoder
It's what's in their document. Some of the older Class As were built on a Chevy chassis, I think (or at least they had a 454 engine), so I wonder if that's what caused it.mtodd54 wrote:Thanks Skater - that's really slick! Worked great - the only think that looks funky is the Series mentions 'chevy'... maybe thats in the airstream DB.
[image][/image]
- B190 Year: 1989
Re: VIN Decoder
The VIN decoder worked fine for the vehicle - 1FDHS34G5KHA85388. Returned the correct information.
I had difficulty identifying what would be the Airstream Number but found a difficult to decipher model number on a foil label on the post of the drivers door. It read VC2RT-111, and it returned 1969-1980 era serial 111 1960 model. No other information on that label seemed to fit and the length of the number was accepted.
I would be interested in what the Airstream number should look like.
Re: VIN Decoder
That's an Okanagan model number, not an Airstream serial. For the B190s, the Airstream serial starts with 1B9 and looks just like a 17 character VIN (because it is). Prior to 1980, Airstream VINs followed different rules, but that doesn't matter for B vans. The Airstream serial - which you may not have - is usually stamped on an aluminum plate under the hood.Abie Sea wrote: ↑Mon Dec 31, 2018 6:11 pmThe VIN decoder worked fine for the vehicle - 1FDHS34G5KHA85388. Returned the correct information.
- Julief8
- B190 Year: 1997
Re: VIN Decoder
Here are my VIN Results. Very Wrong... Its a 1997 Unit on a 1996 Ford Econoline 350 Van. It does not have a Chevy engine. It's not a 1982 or a 2012 model. By using a pdf file I saved last summer I get much more accurate results. Any reason why?
1B9KGVAZXCJ301191
VIN Decode Results
Variable Name Value
Airstream Results:
VIN Length Pass (Post-1980 Airstream)
Manufacturer Airstream B-Van
Type of Trailer Rear Bath
Series Motorhome, Front Gasoline Engine, Chevy
Body Type B-Van, high roof, (Ford)
Length 19' to less than 20'
Axles Unknown
Model Year 1982 or 2012
Site of Manufacture Jackson Center, OH
Serial Number 301191
Check digit Fail - calculated: 7
Data Source Airstream documentation
1B9KGVAZXCJ301191
VIN Decode Results
Variable Name Value
Airstream Results:
Axles Unknown
Re: VIN Decoder
Because the VIN you entered is wrong - the check digit calculation failed. (Also, the Chevy thing was discussed above.)Julief8 wrote: ↑Thu Jan 03, 2019 11:02 pmHere are my VIN Results. Very Wrong... Its a 1997 Unit on a 1996 Ford Econoline 350 Van. It does not have a Chevy engine. It's not a 1982 or a 2012 model. By using a pdf file I saved last summer I get much more accurate results. Any reason why?
1B9KGVAZXCJ301191
VIN Decode Results
Variable Name Value
Airstream Results:
Axles Unknown
With the correct VIN (1B9KGVA2XVJ301191):
Axles Double axle
Model Year 1997
Check digit Pass
Edit: I added a note to the decoder about the Ford/Chevy thing because I see I'm going to get many comments about it if I don't.
Re: VIN Decoder
Hi I put in my Airstream VIN number for 1995 b190
1B9KGVA29SJ300979
And it didn't come up with any results. Any ideas why? Thanks for your reply.
1B9KGVA29SJ300979
Re: VIN Decoder
It's working for me...did you check the Airstream checkbox?
Re: VIN Decoder
I've made a few tiny updates to this to fix some minor issues:
- For the Airstream VIN decoder, it would fail if you didn't use capital letters. Fixed.
- If you don't check one of the boxes, it tries to guess which one you wanted. If the VIN starts with 1B9, it runs the Airstream decoder. Otherwise, it runs the chassis decoder.
Re: VIN Decoder
Got mine!
Also, here’s the info...
Purchased September 16, 2020 in Denver Colorado. Resides in Denver Colorado. Mileage is 169,125 with a rebuilt engine and replaced transmission in summer of 2020.
4 burner Wedgewood stove and oven, soon-to-be Nova Kool 4500 fridge.
- 32932E9B-B8F5-47B2-A43D-A145A4E685EB.png (530.78 KiB) Viewed 10322 times
- DDA8CC63-F141-451B-BCA2-54AE5ED3F955.png (874.42 KiB) Viewed 10322 times
- E7935081-E21B-45C5-A203-70BCDA969C27.png (495.89 KiB) Viewed 10322 times
- DE0A2E9F-E026-49D0-BC96-B4157945EB2B.png (587.9 KiB) Viewed 10322 times
- BD2E2F3F-54C6-4534-8F6D-2E8987D87BB9.png (470.12 KiB) Viewed 10322 times
‘94 B190 acquired in September 2020. Location: Denver, CO. Three furry CO-captains (2 canine and 1 feline) plus Capt. Zissou, my human husband.
