I have a 1998 microlite 2800 that i am refreshing.
i replaced the fuel pump, carb, fuel line, vibration mounts, painted the base, rebuilt the fiberglass shields, etc.
However,
1. i forgot to take pictures or label the wires for the fuel pump and starting solenoid and cant figure out where the wires go.
there appears to be 3 connections on the solenoid around a band at the base....the fuel pump only has the one white wire...
Does anyone have pictures of the wires for the fuel pump and starting solenoid?
2 The spark plug boot came off the ignition wire, can i just use a generic screw on spark plug boot replacement?
thanks for the pictures and advice.
thanks in advance for your help as i am really excited to finally get my genset back where it belongs!
Fuel pump and starting solenoid wiring
Our79Westy
- New User
