staying cool while boon docking
Any tips on how to stay cool while boondocking? Where both heat and bugs are an issue?
staying cool while boon docking clarification
Oh small detail—the previous owner took out the generator so that’s not an option. I’m considering constructing an awning for the sunny side so that might help.
- Millennial Falcon
Re: staying cool while boon docking
I picked up some cheap Walmart sliding door bugscreens, the kind with magnets to auto-close it again after you walk through? Then got some magnets to stick around the outside edge of the doorframe for the entry door and the rear doors. relatively cheap and easy bug protection!nanook wrote: Fri Jul 16, 2021 5:57 pm Any tips on how to stay cool while boondocking? Where both heat and bugs are an issue?
Opens up the interior to a lot of airflow, and keeps the bugs out. Other than that... a 3000 watt inverter-generator will run the AC.
Thanks. I’ll have to give that a try!
- con5
- B190 Year: 1998
We made bug screens for the front windows with some screen material and magnets. They work great!
Cool idea! Thanks for the pic too!
slapthecat
I had read - and tried once (it seemed to work) - to close the windows/doors/shades on the side of the van the sun is shining on, and open everything on the other side. Did that at a festival last spring and it did seem to keep some airflow going through the van!
