1998 Big Bad B190 4X4 Bay Area, CA
List your B190 and related items here
Locked
LeeH
Post by LeeH »
Photos, videos and details here :
https://1998airstreamb190.godaddysites.com
Selling my super old, low-mileage Airstream B190 camper van for more than most people make in a year.
But you don’t want this van. It’s 26 years old. It’s loud. It’s heavy. Everyone stares at you when you’re driving it. Right now it costs over $100 to fuel it up. It’s a ridiculous and overpriced vehicle.
You don’t need the 6.8L V10 because you’ll not be able to afford anything else to tow behind it anyway. It has less than 70k miles because 10-14MPG just hurts. It recently got new plugs and wires which are a nightmare to replace, and the transmission was just rebuilt with heavy duty parts because, well it weighs as much as a baby humpback.
It’s been converted to 4×4 with a UJoint 6” lift with 35” BFG KO2s and Method wheels on a custom Dana 60 up front that has the largest brake rotors you can imagine, and a custom Sterling 10.5” rear axle with a Ford factory locker. But don’t waste your money – you’re not really gonna off road this thing, you just want it because it has remote-resi Fox shocks on each corner and dual Fox shocks up front so everyone will think you rally this thing like a trophy truck. And to be fair you could.
Yes it has two showers with plenty of hot and cold water. One inside for when you are feeling shy, and one out back for when you want your bits in the wind. But don’t tell anyone you like to shower daily because that’s not hard-core. The Dometic toilet is new and it has massive grey and black water tanks so you can carry your poop around with you until you can find an expensive RV dump. Yay.
It has a gas-powered Webasto heater that you probably won’t use because you’re a fair-weather camper and you’ll only need the MaxxAir fan and 12V Dometic RTX2000 A/C. It has a new Vitrifrigo 12V fridge that is huge and costs way more than the fridge at your house, but that just means you’re gonna pack too much food. And there’s so much storage you’ll run out of things to carry around.
This van also has a propane stove inside because everyone loves to cook in their van while all of their friends are having cocktails and cooking together outside. And it has an oven for those times when you just have to bake a cake on the road. The truth is you’ll just use the oven to carry more stuff.
The van has 400AH of lithium power, 400W of solar on the roof, a REDARC Manager 30 and the Rogue TVMS System which is more expensive than your first car. This does mean you could be off-the-grid permanently, but let’s face it, you can’t get much time off because you’re working too much to pay for this thing.
All of the electronics can be controlled by your phone so you can show your buddies how lazy you are, and two REDARC screens give you all of the information you don’t understand and don’t care about. The controller next to the driver also controls all of the lights, rear locker and could be configured to control just about anything you want. It even gives you internal and external temperature so you can decide if it’s too cold to go outside.
It’s got a massive Fiamma awning that you won’t use because it’s just too much work to turn a handle, and the rear locking storage box form Aluminess is an overpriced place to carry all of your overpriced firewood.
It sleeps four, but two of you have to be gymnasts to reach the top bunk. A bamboo table top on a Lagun mount makes if feel fancy inside.
It has a hitch in front and another in the back so everyone will think you’re really sporty. The front UJoint and rear Aluminess bumpers with all of the Baja Designs lights cost more than some college degrees, and we all know that 12k Warn winch with synthetic line and wireless remote will never see any action. But at least people will think you’re rich.
There’s a lot more, but let’s face it you’re much better off dropping six figures on a bloated Sprinter. You’ll get way more Insta likes. The only good thing about this rig is that you can live in it comfortably when your significant other kicks you out of the house after they find out what you spent on it.
Since you’re still reading, here are the specifics :
Exterior :
Basalt Grey & Black Raptor Liner
UJoint aluminum FB003 front bumper with Warn Zeon 12S Winch
Warn Epic Shackles
Aluminess rear bumper with in-bumper storage
Full size spare on swing out
Owl Van storage box with shelf, axe and DMOS shovel
35×12.5×17 BFG KO2s on Method wheels
UJOINT Offroad 6″ 4×4 conversion with remote-resi Fox Shocks
UJoint Stage 2 Dana 60 with 14″ rotors & Premium Warn Hubs
Custom rear 10.5″ Sterling full float axle
Yukon 4:56 gears & OEM Ford rear locker
UJoint Overload Airbag Kit
12V Dometic RTX2000 Air Conditioning Unit
Two Baja Designs LP9s, six 4″ BD Squadrons, two BD S1s
Two Rigid dimmable scene lights on each side
AGM chassis battery with upgraded 250A alternator
400AH Lithium Coach Batteries replaced Onan generator
400W Renogy Solar Panels, expandable solar connection
32 gallon fresh water tank, 6 gallon LP water heater
Grey and black tanks with new valves
All tanks kept warm with venting from Webasto furnace
External 30A connector, city water inlet & filler
Fiamma Awning with leg mounts on van
Aluminess ladder to nowhere (well to clean the solar panels)
Ford OEM powered tow mirrors
LED headlights with integrated turn signals
New starter, plugs, wires and fresh oil change synthetic 5W30
Humvee military scissor lift with Agile Offroad frame/axle adapter
Registered in CA through October 2025
I’m sure there’s more…
Interior :
Ceiling & main walls removed and replaced with new custom wood panels, wrapped in Marathon grey fabric
New 3M Thinsulate and Havelock wool insulation
Replaced 90% of original fiberglass insulation
Wolfbox Dashcam / rear view camera
REDARC Manager 30 BMS with dual control panels
REDARC Rogue TVMS System with BT connectivity
Transfer switch ready for inverter
Original solid oak cabinets, doors & drawer fronts refinished
Sanded & painted with BEHR premium enamel paint
New hardware, fasteners, soft-close drawer slides
New flooring insulation, plywood and Lonseal vinyl (one piece)
Upgraded new jackknife sofa / bed with underseat storage
Custom sewn privacy curtains and window coverings
New top bunk foam padding with memory foam & custom covers
Extended top bunk with LED lights / USB chargers
Large interior rear garage storage / ski locker
Webasto gas heater with digital controller and thermostat
New larger Vitrifrigo 12V fridge with freezer
Upgraded front seats with late-model OEM black leather seats
Upgraded radio with 10″ floating screen, wireless Apple CarPlay
Rockford fosgate speakers & powered subwoofer under sofa
Lagun table with bamboo table top
Generous amounts of sound deadening
2009+ driver and passenger door interior cards
Maxxair front fan with remote & new shower fan / light combo
Marine hot/cold shower mixers for interior and exterior showers
Quick disconnect hoses with multiple shower spray patterns
Upgraded kitchen faucet with pull-out sprayer
Guzzle H2O multi stage water filtration system with UV light
REDARC Tow Pro Elite Trailer Brake Controller
10,000lb rated hitch in the rear. Additional hitch receiver up front
So many more things I just can’t remember…
Re: 1998 Big Bad B190 4X4 Bay Area, CA
Wow, that's a beast.
Per the site rules, please add the VIN. Thanks.
Now on Bring a Trailer.
VIN is 1FDSS34S0WHA07004.
Locked
