Alaskan has some very good tips and pictures on removing the Onan 2800 in the thread:
Onan Microlite Fuel Pump.....
He posts as follows:
"Removing the generator involves disconnecting the exhaust pipe and dropping it down to start with, next you'll find that your generator has a couple bolts holding it down, either inside the enclosure or up from the bottom, Airstream did that 2 ways. (Mine was bolt through from underneath - reday)
Once you have removed those fasteners you can slide the generator out far enough to disconnect the fuel line, a small electrical plug, a 12 volt positive cable and the 110 volt output lines.
Sliding the generator straight onto a pair of stacked milk crates works pretty well as they are near the right height... "
I would like to add the following:
This is a very tight vertical fit. You need to tilt the front up, lift and slide the unit forward. Mine came out 4-6 inches and would come no further. There are bolts, protuberances, whatever that it will hang up on. I could not get it any further until I slid two plastic strips about 1.5 in wide by 18 long and .25 thick. I put these under what I could see as the lowest point on the bottom of the generator and resting them on the opening lip. By doing this, I was able to then lift and slide out over whatever I had previously been hanging up on easily.
I am going to assume that this will also help me on getting it back in by reversing the procedure. I will determine that when I get whatever new parts are needed to get the generator up and running again.
Removing Generator
- reday
- B190 Year: 1995
Removing Generator
