Why disconnect the battery?
I am in the process of setting up my new (2008) Jeep Liberty for towing. The owners manual says to disconnect the battery before towing. Does anyone know why? If it is to simply reduce battery drain, can I connect the Jeep battery to the hot wire on the B van trailer plug?
- reday
- B190 Year: 1995
I tow my 04 Liberty behind the 03 MH. I have not run across anything that mentions disconnecting the battery while towing. Is this instruction in the context of RV towing? The way mine is set up the brake lights (additional lights added inside taillights) are powered from the MH with no drain on the Liberty battery.
Although I could, I have no plans for towing the jeep with the 190. I don't think I would try it without a braking system and unless I sell the MH I am leaving the brake compressor on the MH until that decision is made...
If I need to head out anywhere I would just go in the 190. Thinking about towing a trailer for all the gear that I am used to having on the MH and just leaving that behind at the campsite.
We are just both looking at this from different perspectives and starting points...
But, back to your question, I see no reason to disconnect.
