excessive sway
cooperlawn
excessive sway
Have been on the road since Dec12.In the 94 b190 as reported earlier little problems here and there.But, Had the shocks replaced out here on the road at a BIG O in Arizonia.The b190 drives excellent on the big roads but, here is the problem i pull into a lot or on the way out off a lot the van is swaying so bad i feel like it is going to flip.And, that is bareley moving while entering or exiting.Any advice or help would be appreciated..
Re: excessive sway
Do some research here on sway bars and bushings.
Good luck,
Gary
Good luck,
Gary
Re: excessive sway
Also, air bellows, or what ever there called between the rear springs and the frame did the trick for me.
- RCR
- B190 Year: 1995
Re: excessive sway
1995 WHITE B190 7.5L - 108k
