Front and rear fully loaded weights
AIRticulated
- B190 Year: 0
I have a 1996 B190. Has anyone had their van on scales weighing the front and rear individually while being fully loaded? Through searching the site I have gathered the total loaded weight is usually just over 9000 lbs. Is this accurate? I am looking for the individual front and rear weights. If you have had this measured could you list the info on your rig, how it was loaded and what those weights were. Thanks in advance ladies and gents.
Re: Front and rear fully loaded weights
I have 1997 and it weighed 1,760 lbs on the fronts and 2,650 lbs on the rears,
total 8,820 lbs. I do not now though what I had in the tanks so a total weight of
9,000 lbs is absolutely realistic.
Air7111
Air7111
